datalogging with aem wideband.
Old Jan 29, 2010 | 04:51 PM
fossilrunner's Avatar
Default datalogging with aem wideband.
how do I data log my aem wideband to my pc. I see it has the wire to do so but what do I hook this up to? btw car is not computer controlled. Its my nova thats running e85
this is the part in the instructions where im confused "RS 232 serial data output port for data logging without an engine management system" . what exactly do i do with the wire?
Old Jan 30, 2010 | 11:15 AM
Ok i researched this a little more. Can I use the innovate logworks software with the aem wideband
Old Jan 30, 2010 | 04:07 PM
shoemike's Avatar
I doubt it unless you are a good hacker, the serial protocol is most likely not the same.
I know you can view it thru HyperTerminal but it would not do you any good without a way to log
AFR against MAP or at least RPM ect.
An external data logger is your best bet.
Old Jan 31, 2010 | 01:34 AM
like which one?
Old Jan 31, 2010 | 09:31 AM
shoemike's Avatar
Innovate Motorsports has a few.
