tuning with converter swap?
Old Mar 1, 2010 | 03:07 PM
horcpowr's Avatar
Default tuning with converter swap?
I didn't really know where to post this and couldn't find much in my search. I have a 93 Z28(speed density) and i am putting a Yank SS3600 in it. Do i need to have the computer tuned for this? I would think not since the trans is non electronic but i need advice from someone who knows or has done this in a 93. Thanks
Old Mar 2, 2010 | 02:37 PM
horcpowr's Avatar
Anyone????
Old Mar 6, 2010 | 10:30 AM
LS1FBIRDTA's Avatar
for 700r4 you might be able to change shift points but thats about all, be careful with too high of a stall though sometimes it screws w/ the lock-up & can even negate it completely, I'm runnin a hughes hybrid 10" 3200 stall on my daily driver 91 formula ls1 wich is a 10" front hub(for less rotating mass) mated to a 12" rear half for maintaining the best line pressure & cooling in lock-up a bit pricey but well worth the added protection on the 700r4's, wich need all the help you can give 'em (both of mine have been totally rebuilt w/ all the tricks you can do, like upgraded pump & input shaft as well as 1-2 & 3-4 servos just to name a few, theres alot of "tricks" fot the 700's to keep them runnin strong.
