A4 To M6 Tune?
there's quite a lot of differences just in the engine part of the PCM, between an A4 and an M6 tune file of the same car model.
Just find an M6 file of the same year, or at least the same Operating System and flash that in.
Went through this in 2003 myself.
PM if you need any help.
would be carry over and lowering some airflow tables would eb all that is needed?
Yes, he is correct...
I must have been overstating the case a little. The only differences in the engine calibration between an A4 and an M6 MY2000 T/Am are listed below:-
Comparison summary: 09:19:56 pm, Wednesday Mar 10, 2010
Calibration comparison between 2000 Pontiac TransAm Coupe Manual LS1 5.7 Litre (09381344).tun and 2000 Pontiac TransAm Coupe Automatic LS1 5.7 Litre (09381344).tun.
*Values that differ by more than 0.000001% are considered different.
B1201 "Abuse Management (in Gear) Upper RPM Threshold" -35.9380 "CAL: 6600 <-> ALT: 2000"
B1202 "Abuse Management (in Gear) Lower RPM Threshold" -39.0631 "CAL: 6500 <-> ALT: 1500"
B1203 "Abuse Management (in P/N) Upper RPM Threshold" -35.9380 "CAL: 6600 <-> ALT: 2000"
B1204 "Abuse Management (in P/N) Lower RPM Threshold" -39.0631 "CAL: 6500 <-> ALT: 1500"
B1205 "Abuse Management TPS Upper Threshold" -94.9023 "CAL: 100 <-> ALT: 5"
B1206 "Abuse Management TPS Lower Threshold" -95.9961 "CAL: 99 <-> ALT: 3"
B1207 "Abuse Management Vehicle Speed Threshold" 99.6124 "CAL: 0 <-> ALT: 410"
B1209 "Abuse Management Time" 0.3662 "Different from row 0 to row 15 inclusive."
B3632 "After-start Coolant Temp Enrichment" 0.0458 "Different from row 4 to row 4 inclusive."
B3631 "Park to Drive Enrichment Decay Rate" 0.3922 "Different from row 5 to row 15 inclusive."
B3651 "Park to Drive Enrichment Decay Factor" 0.7813 "Different from row 6 to row 15 inclusive."
B3331 "Fuel Re-enable in P/N" 0.7034 "CAL: 6100 <-> ALT: 6190"
B3307 "DFCO Re-Enable Timer" 1.2207 "CAL: 0 <-> ALT: 5"
B3314 "DFCO Vehicle Speed Enable" 3.1251 "Different from row 0 to row 4 inclusive."
B3318 "DFCO RPM" -4.6876 "Different from cell: 0,0 to cell: 1,7 inclusive."
B3320 "DFCO MAP" 2.8651 "Different from cell: 0,0 to cell: 1,4 inclusive."
B3610 "PE Delay RPM Bypass" 25.0004 "CAL: 0 <-> ALT: 3200"
B4111 "STFT Base Correction at Non-Idle" 2.4414 "Different from row 1 to row 8 inclusive."
B4103 "Closed Loop Idle Throttle Position" -3.0078 "CAL: 5.00 <-> ALT: 1.99"
B4107 "Closed Loop Mode" 15.6250 "Different from row 9 to row 14 inclusive."
B3415 "Wall Wetting Min RPM" -1.1719 "CAL: 450 <-> ALT: 300"
B4602 "Max Idle RPM in P/N" 9.3751 "CAL: 0 <-> ALT: 1200"
B4613 "RPM Set Point Adjust in P/N" 3.9063 "CAL: 0 <-> ALT: 2"
B4614 "RPM Set Point Adjust Timer" -0.1221 "CAL: 0.5 <-> ALT: 0.0"
B4603 "Desired Idle Speeds" 8.2033 "Different from cell: 0,0 to cell: 3,15 inclusive."
B4307 "Desired Airflow" 28.2811 "Different from cell: 0,0 to cell: 1,9 inclusive."
B4308 "Airflow Parked" -1.5625 "Different from row 7 to row 9 inclusive."
B4353 "Idle Spark Control Delay" 0.4883 "Different from row 0 to row 16 inclusive."
B4303 "Startup Airflow Correction" 3.1250 "Different from cell: 0,0 to cell: 1,5 inclusive."
B4306 "Startup Airflow Decay in Park Neutral" 3.1992 "CAL: 0.00 <-> ALT: 0.80"
B4348 "Startup Airflow Multiplier When Exiting Idle in Park/Neutral" 100.0000 "CAL: 0.00 <-> ALT: 1.00"
B4343 "Startup Friction Airflow Correction" 4.9851 "Different from row 0 to row 4 inclusive."
B4344 "Startup Friction Airflow Decay" 0.0397 "Different from row 2 to row 9 inclusive."
B4322 "Idle Learn P/N Limit High" 0.7813 "CAL: 0.00 <-> ALT: 0.50"
B4323 "Idle Learn P/N Limit Low" -4.6876 "CAL: 0.00 <-> ALT: -3.00"
B4327 "Idle Learn A/C Limit Low" 0.7813 "CAL: -0.50 <-> ALT: 0.00"
B4514 "Learned Airflow Correction" 0.0305 "Different from cell: 0,1 to cell: 3,16 inclusive."
B4515 "Direct Airflow Correction" 0.0980 "Different from cell: 1,4 to cell: 5,16 inclusive."
B4521 "Maximum Idle Short Term Correction" -6.2501 "Different from row 0 to row 5 inclusive."
B4309 "Throttle Cracker Airflow in Gear" -3.4379 "Different from cell: 0,0 to cell: 16,11 inclusive."
B4313 "Throttle Cracker Decay Rate" -0.1175 "Different from row 0 to row 3 inclusive."
B4314 "Throttle Cracker Decay Delay" -100.0000 "Different from row 4 to row 16 inclusive."
B4317 "Throttle Follower Decay Rate in Gear" 0.1236 "Different from cell: 0,0 to cell: 3,17 inclusive."
B4318 "Throttle Follower Decay Delay in Gear" -0.7080 "Different from row 0 to row 17 inclusive."
B5913 "Spark High-Octane Table" -14.2927 "Different from cell: 1,0 to cell: 23,4 inclusive."
B5914 "Spark Low-Octane Table" -14.2927 "Different from cell: 1,2 to cell: 1,2 inclusive."
B5932 "Base Spark in Gear" 7.0381 "Different from cell: 0,0 to cell: 23,4 inclusive."
B5933 "Base Spark in Park/Neutral" -8.5831 "Different from cell: 0,0 to cell: 28,2 inclusive."
B5911 "Spark IAT Table" 9.4482 "Different from cell: 4,9 to cell: 16,20 inclusive."
B5901 "Catalytic Converter Light-off" 5.5664 "Different from cell: 0,2 to cell: 12,6 inclusive."
B5902 "Cat Light-off Temp Multiplier" -25.0000 "Different from row 8 to row 8 inclusive."
B5903 "Catalytic Converter Light-off Max RPM" -0.6256 "CAL: 1880 <-> ALT: 1800"
B5904 "Catalytic Converter Light-off Re-Enable" -0.7813 "CAL: 1800 <-> ALT: 1700"
B5915 "Minimum Spark Advance" 13.3301 "Different from row 0 to row 20 inclusive."
B5917 "Base Spark Vehicle Speed Threshold" -15.2348 "CAL: 69 <-> ALT: 6"
B5920 "Spark Smoothing Enabled" N/A "CAL: Enable <-> ALT: Disable"
B5926 "Min Coolant Temp for Spark Smoothing" 5.5568 "CAL: -10 <-> ALT: 0"
B5927 "Max Coolant Temp for Spark Smoothing" -77.7730 "CAL: 140 <-> ALT: 0"
B5928 "Min Engine Run Time to Enable Spark Smoothing" -3.6622 "CAL: 15 <-> ALT: 0"
B5924 "Spark Smoothing Limit (Closed Throttle)" -7.8106 "Different from cell: 0,0 to cell: 1,9 inclusive."
B5930 "Speeds for Spark Smoothing" -23.4382 "Different from row 0 to row 1 inclusive."
B5931 "RPMs for Enable Spark Smoothing" -37.5006 "Different from row 0 to row 1 inclusive."
B3336 "DFCO Spark Timing" -6.6650 "Different from row 5 to row 20 inclusive."
B5939 "DFCO Spark Timing, Low TPS" 5.5664 "Different from row 3 to row 4 inclusive."
B3335 "DFCO Spark Ramping Out Rate" -0.2232 "Different from row 0 to row 1 inclusive."
B6208 "Burst Knock Min Coolant Temp" 5.5568 "CAL: 60 <-> ALT: 70"
B6213 "Adaptive Spark Min MAP" 14.2884 "CAL: 50 <-> ALT: 65"
B6204 "Knock Retard Limit Not in PE Mode" -6.2313 "Different from row 5 to row 16 inclusive."
B6205 "Knock Retard Limit When in PE Mode" -2.7294 "Different from row 1 to row 4 inclusive."
B6212 "Burst Knock Retard" 6.2485 "Different from row 1 to row 1 inclusive."
B6245 "Knock Sensor Multiplier B (Cylinder Mode)" 37.5000 "Different from cell: 0,6 to cell: 7,7 inclusive."
B1905 "Stall Speed" -4.6876 "CAL: 600 <-> ALT: 0"
B6603 "TCS Spark Retard" 3.1242 "Different from row 1 to row 10 inclusive."
B6604 "TCS Spark Retard Fast" 1.5621 "Different from row 1 to row 4 inclusive."
C6001 "Engine DTC Processing Enablers" N/A "Different from row 43 to row 217 inclusive."
C6002 "Engine DTC MIL Enablers" N/A "Different from row 85 to row 217 inclusive."
C3208 "Post-catalyst O2 Transition time - first" 6.0000 "CAL: 7 <-> ALT: 9"
C5606 "Misfire Detection Min RPM" -1.9532 "CAL: 650 <-> ALT: 400"
C5611 "Misfire Detection Transmission Delay" 0.0107 "CAL: 0 <-> ALT: 7"
C5621 "Misfire Idle per Cylinder Mode" 49.9031 "Different from cell: 0,1 to cell: 9,16 inclusive."
C5622 "Misfire Low RPM per Cylinder Mode" 49.8772 "Different from cell: 0,1 to cell: 9,16 inclusive."
C5623 "Misfire Mid RPM per Cylinder Mode" -49.9870 "Different from cell: 0,1 to cell: 9,16 inclusive."
