Do I need to retune?
Old Mar 10, 2010 | 08:37 PM
David Q's Avatar
Default Do I need to retune?
Installed h/c/i, ported tb, longtubes, converter and then had the car dyno tuned. When I tuned the car I had the factory mufflers on it, now I have dynomax race bullets dumped before the axle. I have only driven maybe 200 miles since the original tune. Do I need to have the car tuned again? I don't know if I am just used to the car now or if it got slower after the muffler install. It feels like it does not pull as hard at the top end of 2nd and 3rd gear. Also twice now while driving all of the gauges instantly pegged out and then returned to normal, just like it does when you fisrt turn the key on. The car never actually lost engine power just flashed the gauges. Does that mean anything?
Old Mar 13, 2010 | 07:33 PM
its allgood's Avatar
I'm intrested in the answers you receive. but it would help to know what your car is and mods.
Old Mar 14, 2010 | 07:58 PM
racecar's Avatar
It's going to flow a little better with an open exhaust.
If you really want max performance, yes tune it, but it is probably pretty close.
If the gauges flash while you are driving, you probably have an elec issue.
Are there any codes?
Old Mar 17, 2010 | 10:08 AM
B4Cya's Avatar
I'd definitely have it re tuned if you had it tuned on factory mufflers with all those mods, then went to dumped exhaust setup.
Old Mar 17, 2010 | 06:30 PM
scites's Avatar
check all your grounds and asl look around you headers and make sure there is nothing melting and grounding out
Old Mar 19, 2010 | 03:57 PM
2000SS1979's Avatar
I had this same thing happen to me when my alternator started to fail. I replaced it and it never happened again.
Old Mar 19, 2010 | 05:48 PM
bww3588's Avatar
yes, your gauges shouldnt sweep when you first start it. when they do that it usually means your battery is getting weak.
