Need Pillar gauge connection help!!!
And for the water temp gauge sender, the common place is in the head by the #8 cylinder, but if you have ever looked back there, it is damn near impossible to get the sender in. I put my sender in a plug that is just above the starter. It is very easy to access and only requires you to unbolt the starter, then remove the plug thats in the block. Watch out, a boatload of coolant will come out of this hole! You need to buy an adapter for this location, the ones that came with the gauges will not fit. I believe the size is M16x1.5 with the 1/8" in the middle for the actual sender. Then I routed the wire up along the loom for the oxysensors which goes up the the PCM. I wraped the wires in loom also to protect them. Then run the wire through the grommet in the firewall which it just behind the PCM. Use a coat hanger to pull the wire through, no need to remove the PCM. Good luck!
