fan temps
Above 230F I start getting nervous. Maybe these engines can take 250F, but that would scare me.
Good luck.
If coolant is 230F, then oil is @ least 260F+, more likely 280F. Regardless, LT1's, IMO, aren't as wimpy toward higher engine coolant temps, as are LS1's. The stock rings in my LS1 & LS6 short blocks have lost their sealing ability @ 245*F (coolant temp); lesson learned. I only use "Hellfire" rings now so that if she gets hot, I don't have to re-ring the pistons.
