Drivability problems
After those are ruled out, you're down to the wiring, sensors, injectors, coils as major probable causes.
Wiring is fine, Ive tested it multiple times. Sensors show a good reading on the scanner and react correctly for each circumstance
Injectors were swapped, same issue
Coils swapped, same issue
1) HPTuners
2) Tune and driving log are posted on pg 2, beyond that I know nothing of of whats inside the PCM
Once you rule out the wiring, hook up a scanner and get a live feed of all your sensors. Faulty ones will stick out. My car showed good readings for everything so it was esp frustrating. Doesnt hurt to check the basics
Does HP Tuners give any feedback if the re-learn was successful? I am still wondering if it actually re-learned.
I had same problem , the car misfired a bit on two cyl and ran like crap tried all
then did CASE learn and the car stopped misfire and solved my problem....
thanks for your threat
Baezi
