bogging at 2000
Old Apr 3, 2010 | 10:08 PM
1998ls1z28's Avatar
Default bogging at 2000
ok i have been tuning my own car for a year now no problems. i put a mild cam on top of all the bolt ons i have. the car has 85mm tb and intake manifold with long tubes off road y pipe loud mouth 1 2800 stall and 3:73. i tuned it and the car runs great idles right at 850 no problems has tons of power but when i took it to the track on wendsday the car would bogg at 2000 rpm when i would try to get up on the converter then would "drive" out of the whole. im thinking its running to lean at low rpms to come up on the convert. any ideas?
Old Apr 3, 2010 | 10:13 PM
19BLACKBIRD99's Avatar
Check them O2s haha
Old Apr 3, 2010 | 10:18 PM
1998ls1z28's Avatar
if it was the o2s wouldnt it run lean through out the rpm range? cuz it runs strong as soon as it gets above 2500 rpm. wendsday the car went 12.9 with a 2.08 60' there were no problems with the o2s before i did the cam swap
Old Apr 3, 2010 | 10:19 PM
1998ls1z28's Avatar
as soon asi get off the converter it will pic up after 2500 rpm. if i jump on it from a dead stop it wont even spin the tires till top of 1st gear when the rpms come up
Old Apr 3, 2010 | 10:21 PM
hmmm, well on my auto 99 I just had put headers on it, and I didnt have extensions yet, and it bogged just like your saying, might just be the cam? might be stronger past 2000
Old Apr 3, 2010 | 10:23 PM
1998ls1z28's Avatar
the operationg range of the cam is 1500 to 5500 that why i couse that cam. my car before the cam was pulling 1.65 60' so its really bogging bad.
Old Apr 3, 2010 | 10:28 PM
I dunno man, if you have a tuner it should be throwing a code if it was the o2's so if its not im not sure what the problem would be.
