rich idle, in the tune or something else?
Old Apr 19, 2010 | 12:40 PM
boosted89tta's Avatar
Default rich idle, in the tune or something else?
Hey all....
I have been a ford guy all of my life and recently purchased an 04 vette and I love it.
I just finished up doing a G5X3 112 cam and spring install and long tubes and offroad xpipe install. These are the only mods on the car at the moment. I had a friend who is very good with these help me tune the car with hptuners and it runs terrific, has no knock at WOT but we have a rich idle problem. It's rich enough at idle to make a moderate cloud.
We adjusted the VE table down and smoothed it, took a lot of timing that gets pulled out and turned the rear o2's off and the normal stuff you would do to one. No matter what changes you make it still idles rich. Right now I am running it in open loop and it's still rich. When you unplug the maf in open loop it's still rich. The only thing I haven't done yet is put my new plugs in it because I don't want to foul a new set of plugs knowing its going to be too fat at idle. Does anyone have any ideas?
I can email anyone a copy of the tune if needed, I am not sure how to upload it on here. I bought the hptuners so I could tune my own car as I make changes to it. I am beginning to get a little frustrated. The only codes on the car are some u and b codes that most people on here have said to ignore.
Ryan
Old Apr 19, 2010 | 12:43 PM
I also wanted to add that when you trim the ve table down in the idle range by 50% it still idles rich and will barely run, if you fatten it up it's rich. If you use the vcm scanner and set the manual afr to 18:1 it's still rich... just hoping for some ideas here....
Old Apr 19, 2010 | 01:25 PM
HUNTER02SS's Avatar
Did you tune the VE with a Wideband or the factory Narrowbands.
Old Apr 19, 2010 | 02:42 PM
edcmat-l1's Avatar
Sounds like you're tuning the VE with the MAF still enabled. That's why you're scaling the VE and it's not making any difference in the fueling.
Can you post a tune and run log?
Old Apr 19, 2010 | 04:39 PM
I can run a log later this evening and can post the tune, how are you guys uploading the tune to post it? Just attaching a file?
Old Apr 19, 2010 | 05:15 PM
BLK02WS6's Avatar
As said above, are you using a wideband?
Have the injectors been changed, or are they stock?
Check engine coolant temp on the log to make sure the sensor isn't unplugged, broken, or anything like that - that commands way rich AFRs.
Old Apr 19, 2010 | 06:08 PM
white01ss's Avatar
Unplugging the MAF is the wrong way to go open loop. I think it goes into limp mode or something. Whatever it is, you can't tune with it like that.
If you want to go into open loop speed density (OLSD) to run solely on the VE table there should be some help on hp tuners web-site to do that. But don't do it blind, dude. Get a wideband.
Old Apr 20, 2010 | 11:47 AM
I am running open loop by only enabling closed loop at 250 degrees, I only unplugged the maf to see how it idled on the VE table by itself, I then plugged it back in. I do not have a wide band at the moment and I shouldn't need one for this problem because we are talking about idle, we arent talking about being rich or lean at driving speeds or under WOT the car is fine in those areas. At 6600 it shows no knock, timing mark on the plugs looks perfect and plugs look good. The car just idle's rich enough to make a moderate cloud and in traffic it can be somewhat frustrating to be driving a vette that is smoking. I haven't been able to make it idle lean yet even doing crazy drastic changes
The coolant temp sensor is working, the IAT is working also. Keep in mind the car is stock other than cam, valvesprings, long tubes, and offroad x-pipe. These are the only mods right now
Here is the tune on the car and the DTC's from two days ago, I still haven't gotten a chance to run another log to save it
File Type: hpt
File Type: txt
Old Apr 20, 2010 | 12:45 PM
BLK02WS6's Avatar
Well, if you don't have a wideband, how do you know its rich? Maybe its not rich at all - maybe its oil smoke... did you replace the valve seals when you did the springs?
Old Apr 20, 2010 | 04:39 PM
edcmat-l1's Avatar
That tune is not in SD. This one is......april21.SD1.hpt
Also, you didn't have enough idle timing in it for that cam. Probably needs to be even leaner at idle too (lower VE).
Old Apr 20, 2010 | 11:36 PM
It's not oil smoke, it brings you to tears if you stand behind it for more than a few seconds.
What do you mean by it's not in SD? Sorry if thats a stupid question...
Old Apr 21, 2010 | 07:18 AM
edcmat-l1's Avatar
Download the tune I posted for you, and do a compare. The first tune you had posted was not in speed density, so any changes to your VE table you were making, weren't really making any changes. That's why you were making those changes and there was no difference in your fueling. If it's not in SD, you can't tune the VE.
Old Apr 22, 2010 | 10:57 PM
here is a log of it pulling in the garage tonight, and the tune I was fooling with trying to lean it out with no success. I tried the tune you modified, cut the VE table under 1400 by 15% and it wasn't as rich, it eventually threw a MAF code on that tune and started huffing smoke again. I reflashed it with the tune below to pull it in the garage and it huffed right in to it's parking spot. Log and tune below
File Type: hpt
File Type: hpl
Old Apr 22, 2010 | 11:38 PM
5.7 ute's Avatar
Are you hitting a minimum pulsewidth limit?
Old Apr 23, 2010 | 07:32 AM
edcmat-l1's Avatar
I think I would look elsewhere for the cause of the smoke. The NBs in that log are rock bottom. It looks lean as hell.
Are you using a wideband? Log that into your HPT so we can see.
BTW, a speed density tune SHOULD set a MAF code. FYI.........
Old Apr 23, 2010 | 11:34 AM
white01ss's Avatar
If your MAF and VE settings get too far from each other you will throw a code. Also, VE changes while a MAF is enabled will have little to no effect. If your MAF is still enabled, lower the idle cells in the MAF sensor calibration table. Also, make sure your still in open loop or the narrowbands will run the show.
Old Apr 24, 2010 | 07:08 AM
BLK02WS6's Avatar
Bringing you to tears is a sign of lean, not rich!!!
Why do so many of you guys on here insist on trying to tune your own car without the proper tools... GET A FREAKIN WIDEBAND ON IT!!!
This is why I get frustrated on here and don't want to help people...
Old Apr 25, 2010 | 01:39 PM
I understand your frustration with people, I have to deal with nimrods on a daily basis at work. On the other hand I have just spend 2500 bucks on this car and I am not trying to tune it to go beat on it at the track (yet). I have to wait another paycheck or two to get a wideband, and plan on doing so. I am simply trying to tune it so I can drive the thing to work or to the store without smoking up the other cars at the stoplight.
How can it be lean and smoking rich though? That doesn't make any sense, the plugs are dry/pink/brown on the element and black around the tip of the threads which to me says rich idle, clears up driving... I could easily be wrong, and I will get an LC1 or something similar in a week or two to work from there...
Ryan
Old Apr 28, 2010 | 11:12 AM
anyone else have any ideas? I've put 500 miles on this thing and the oil level is steady, not oil smoke, water level full, surely you don't think I need a wideband to tell me something is wrong...
Old Apr 28, 2010 | 03:04 PM
edcmat-l1's Avatar
Dude. Don't know how much more help anyone can be here. Your data log shows both your narrow bands start out about 200mv and drop to about 35mv. So, obviously they are working, and by the looks of it, it's dead *** lean. Not to mention the inj. duty cycle is 2 or 3 percent (3 ms), which by the IFR, that's pretty lean too.
Good luck..........
