VE and AFR question
Old Jan 7, 2004 | 12:16 PM
silent1's Avatar
Default VE and AFR question
Is there a direct link when changing the two tables? What I'm trying to say is, when you multiply your AFR after installing new/larger injectors is there ball park/similar figure to multiply your VE table by? After installing my bosch 42# injectors I was told to multiply my stock values(3.18) by 160-170%, so is there a safe number to multiply my VE table by? Hope this makes sense and thanks for any help.
Old Jan 7, 2004 | 01:28 PM
Texas Terminator's Avatar
don't mess with your ve tables, yet. just use them for fine tuning. leave your afr table alone too. if you change injectors, you need to adjust your injector pw accordingly by looking at your ltrims. there is no set value for your or any other motor for an injector change. if you have idle/starting issues after that, you can tweak your ve tables then. try setting your stock values to around 4.5-5.0 or so and adjust from there. i am around 6.08 with my 57's.
