Newb question
Old Apr 21, 2010 | 12:50 PM
scatterbrained's Avatar
Default Newb question
Hello All!
I couldn't find the answer to this so I figured I'd ask.
I am in the planning stage of putting a 5.3 liter LS based motor in my 68 Camaro. Basic plans include a mild cam, 6 liter heads, and a Tremec 5 speed to go with the Vortech centrifugal supercharger.
The question is:
When looking for a pcm for the engine, does it need to be a pcm for a manual transmission car, or will the pcm from an automatic work? Obviously it will need to be tuned for the cam, exhaust, blower, etc., but if I get a 5.3 from a Suburban with an automatic, will the pcm work with my manual transmission?
Thanks in advance for the help.
Scatter'd
Old Apr 21, 2010 | 04:02 PM
BLK02WS6's Avatar
You can make either work with some enginuity. And you will need a tuner who knows how to work with the limited inputs.
This is similar to when we put racing transmissions in cars with whichever harness. Some wires will need to be worked out to allow the car to start (i.e. clutch switch or neutral safety switch). Does the tremec have an electronic speed sensor output?
Old Apr 22, 2010 | 08:07 AM
Default pcm?
I don't know. The trans isn't readily available to me. I can head over to storage and look, but I was more worried about whatever transmission functions the computer controlled.
As far as tuners, I have several quality tuners here in the Chicago area to choose from.
Old Apr 22, 2010 | 08:51 AM
BLK02WS6's Avatar
You should be fine then - there are ways around pretty much everything - just a matter of getting the harness right and the tune right...
