Rough Starts When warm MORE INFO
My tuner said it is most likely from me over porting my throttle body. Well thats been replaced and I still have the problem.
So now I move onto my O2s. One toggles and one sits dead at 450mv on my interceptor gauge and 360mv on my Fluke.
Another weird thing is that when I unplug the O2s the interceptor is sill showing 450mv. And I switched the O2s from side to side so it makes me believe that my O2s are fine. Im so confused.
The O2s are fairly new since the old ones were nearly dead.
Here are some vids.
STFT1 when warm idle 1-3
STFT2 when warm idle 1-3
When its running crappy right on the startup the INJ PW (ms) 6.5-7ms and when it smooths out and idles fin its 2.5ms
Watch the videos below and you can see me scrolling through.
http://www.youtube.com/watch?v=EKfD6G55-Gc
http://www.youtube.com/watch?v=rN5muz_K-50
http://www.youtube.com/watch?v=nPVQQSE0y4E
http://www.youtube.com/watch?v=WwJ5qB-9i3w
the PCM will be in open loop.
The high ECT areas of the open loop fuel table might be set too rich.
IBPW between 6-7ms at start up makes me think this.
Can you log commanded AFR or commanded EQ?
After start enrichment needs work (hence the high IPW then settling down)...
Startup airflow tables probably need work too...
