Bank 2 Sen. 1 on drivers side???
Old May 11, 2010 | 02:56 PM
WS6Power's Avatar
Default Bank 2 Sen. 1 on drivers side???
My car just threw code P1153 HO25 Bank 2 Sen. 1. What does this mean? Is bank 2 on drivers side?
Old May 11, 2010 | 03:00 PM
2001NBMZ28's Avatar
Bank 1 is drivers side, bank 2 is passenger side. Sensor 1 is precat, sensor 2 is post cat. You can look up the code description/diagnostics at gearchatter.com
Old May 11, 2010 | 05:37 PM
WS6Power's Avatar
Thanks man! What part of Jax do you live in? Ever run Gainesville? So does this mean that I need a new precat O sensor? Could a bad plug be causing this? Car only has 50K miles.
Old May 12, 2010 | 08:53 AM
WS6Power's Avatar
ttttt
Old May 12, 2010 | 09:03 AM
Slow 346's Avatar
Swap your drivers side and pass. side 02 sensor and see if you get a code on bank 1 now. If so...you know its the o2 sensor. If it still pops back up on bank 2...its something mechanical.
Old May 12, 2010 | 03:50 PM
WS6Power's Avatar
Well today I found out what my problem was. I totally melted a spark plug from too much spray. I guess that I need to pull more timing.
