could stock timing still be to much?
Old May 13, 2010 | 07:13 PM
onebadazzls1ta's Avatar
Default could stock timing still be to much?
Still seeing massive kr and my wot fueling isnt right still and I'm at 16% across the board most of it's part throttle KR but I still got it. Have you guys heard of a weak fuel pump causing not enough flow to the injectors....? Or a clogged injector causing KR? And also can you tell if you have a clogged injector?
