Do you need O2's? 2 bar SD
Old May 26, 2010 | 08:20 PM
pwrtrip75's Avatar
Default Do you need O2's? 2 bar SD
On a turbo application, HP Tuners 2 bar SD operating system... what do the front O2's do? Can I leave them out? rears are already long gone and shut off.
Old May 26, 2010 | 08:59 PM
MUSTANGBRKR02's Avatar
Fronts are closed loop. If they are out you will be running 2bar SD OL. Some people do it some don't. Most people who do are usually purpose driven cars. I myself am running 2 bar SD with front 02's.
Old May 26, 2010 | 09:07 PM
Sh0wGoAt's Avatar
^+1
i dont run 02's because i like running leaded race fuel and that kills 02's. but it is a pain in the *** sometimes when the weather starts changing alot as it can not adjust.
Old May 26, 2010 | 10:09 PM
pwrtrip75's Avatar
Reason I ask is my friends BMW we are building, we went through the harness and eliminated all the unneeded wires.... and I think they got eliminated. It would be a pain in the *** to probably rewire them. Just wondering if it will work w/o. Would it just take longer to tune and dial in the VE table? Like you'd have to tune it with each weather change?
Old May 27, 2010 | 07:05 AM
darkhorizon's Avatar
Front o2's I have found are easily fooled by weird cams and non pump gas, so I would ditch them in any case.
The problem is that with SD, your tune is going to be weather effected WAY more than a MAF tune would be, so the front o2's would help if you are going to do a 100% pump gas / stockish cam setup.
maf + no front o2's = awesome
SD + no front o2's = not so much.
Old Jul 26, 2010 | 02:50 PM
maxgee's Avatar
How about E85 running the front o2s?
