LS2 PCM - Controlling Fans Issue
My HP Tuner settings, I have switched to Discrete. Then in the Fan table I have everything zero'd out under 200 degrees F.
My fans are on 100% of the time when the car is on, i'm not really sure why. Am I missing something?
You either tune it out in HP Tuners. "AC Refrigerant pressure sensor", or you can simulate a pressure sensor as follows:
The pressure sensor wires are:
C1-55 : GND
C1-30 : 5v ref/feed
C1-26 : Sensor signal/return voltage
Make a voltage divider out of two resistors (2.2k + 4.9k will do), using C1-55 and C1-30 for the divider, and feed the 1.55v from the centre of the two resistors back into C1-26.
