fuel trims on stock 2002z28
Old May 30, 2010 | 11:35 AM
zrater's Avatar
Default fuel trims on stock 2002z28
at 55 on hiway long trims at -11 on both banks and -6 on both banks
at wot is this right, only real change was timing table and cutout open. thanks
Old May 30, 2010 | 02:25 PM
06MonteSS's Avatar
LS1Tech Sponsor
that's too rich...
at part-throttle, normal driving/cruising, at 1800-2000 rpm, you want the LTFT's to be about 0 to -2....
at WOT, the fuel trims aren't used anyway.. unless they're positive (at which point the pcm will add fuel on top of the PE fueling table), which you don't want - hence the reason to get them slightly negative during part-throttle normal driving...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old May 30, 2010 | 05:22 PM
zrater's Avatar
so a slp lid would do this or timing change or maby cutout open, and can
i lower the maf across the board slightly. thanks much
Old Jun 1, 2010 | 07:27 AM
darkhorizon's Avatar
Bad.
When tuning with narrowbands, only tune in the areas that the narrowband reads... which in most cars is anything from 2% to 40% throttle.
Old Jun 1, 2010 | 04:41 PM
BLK02WS6's Avatar
Your sig shows you have HPtuners and a wideband... why not properly tune the VE and MAF tables?
