PCM out of a 02 s10
i have a 12200411 pcm w/ a escalade engine wring harness...
i am converting over to a drive by cable throttle body, and was wondering if when i reflash the pcm over to that of a 2002 f body, do i need to change the pinout of the ecu to that of a F body?
the reason i ask, is the escalade harness has a lot of extra connectors as well as a fuse block plug i would like to do away with... essentially it will become a stand alone engine & trans harness.
thank you for the help...
see this is what i am unsure of... when you say truck OS, the pinout on the pcm connectors will have to correspond to a truck correct?
i think all the escalades have dbw, so i was confused as to if the pinout is different than a trucks would be that came with dbc...
do you perhaps know where i can find the correct pin designation for the pcm connectors for the truck you speak of online?
i have looked and have been hard pressed to find it...
also the escalade had 4wd i believe? will i have to repin the trans connector as well?
once again, any and all help would be appreciated.
thank you
thank you
The tranny connector is the same with or without 4WD other then the VSS in on the trandfer case in some applications
Email me if you can't find a pin out
