Help with shock sensor removal
Old Jun 16, 2010 | 10:38 AM
koolrayz's Avatar
Default Help with shock sensor removal
I got a little carried away removing extra wiring over the winter. I discarded all if the wires that went back to the spare tire area. I assumed it was all just the stereo crap. Last night i was hooking some things up and realized I have no wiring to the shock sensor.
My question is what ill effects will I see from not having the shock sensor plugged in.
Also I think the wire that feeds the sensor came fron the loom going into the passenger door. I have an "extra" plug left over that comes from inside the door? On the schematic it looks like it comes directly off of the BCM.
Thanks for any help. I will be trying to start the car in the next week and dont want this to be my holdup
Old Jun 18, 2010 | 12:20 AM
faster_n_you98's Avatar
It won't hold you up. I just deleted that entire stereo loom on my car and just ran a 4 speaker system. funny thing is is it sounds better than the monsoon BS
Old Jun 18, 2010 | 08:03 AM
Sunset01TA's Avatar
Hey Ray I think your air bags will deploy on first launch.........................lol
I think its more of an alarm thing.
I have seen a couple of cars with those removed didn't seem to hinder anything.
Not sure if they shut any thing off with the vats?
Good Luck.
PM me when your heading out I'll come crew for you.
Old Jun 18, 2010 | 01:33 PM
koolrayz's Avatar
Good Luck.
I hard wired it back in at the BCM. If all is well I will try disconnecting it after the car is running. I also will disble VATS in the PCM
I will be at door wars next month and I got a drivers ticket for pinks all out.
You going to the nationals next week?
Old Jun 19, 2010 | 12:18 AM
Sunset01TA's Avatar
Yes nick and I will be there on Sat.
