Storm . . . HELP
Old Jun 22, 2010 | 05:53 PM
cryptnosis's Avatar
Default Storm . . . HELP
Pensacola had a bad storm yesterday and i was unlucky enough to drive through it. Now my car is sounding bad, SES light has come on and the car is driving rough. I would like some opinions on what ya think it is? I think the O2 on the left side went out. You can tell something is wrong as soon as you look at the scan. and here are the DTCs
[ECM] P0171 - Fuel Trim System Lean Bank 1 (SES) (Old) (History) (Immature)
[ECM] P0172 - Fuel Trim System Rich Bank 1 (Old) (Immature)
[ECM] P0175 - Fuel Trim System Rich Bank 2 (Old) (Immature)
[ECM] P0327 - Knock Sensor Circuit Low Voltage (Old) (Immature)
File Type: hpl
Old Jun 23, 2010 | 07:31 AM
Old Geezer's Avatar
Water in the O2 plugs??
Maybe time to do some cleanup..IE: clean all the connections, add some dielectric grease, make sure all are tight, no pins loose, bent.
Old Jun 23, 2010 | 06:18 PM
cryptnosis's Avatar
Here is an update.... I lost all codes except
[ECM] P0171 - Fuel Trim System Lean Bank 1 (Immature)
here is a nother run. this time me driving, how do i reset my LTFTs without using HPT Editor.
File Type: hpl
Old Jun 24, 2010 | 04:53 PM
cryptnosis's Avatar
new discovery, day 3 of driving. . . everytime I start the car (after it sitting for a while) and have scanner running it starts of with my LTFT on the left side Maxed out. Everytime, I reset the fuel trims it works PERFECT until I let it sit for a prolong period.
File Type: hpl
