Speartech?
Old Jul 2, 2010 | 03:23 PM
trans2000am's Avatar
Default Speartech?
Try to get some info on them, who all sent there factory wiring harness into them to get rid of stuff not needed. Any issues with it once returned? just wanna make sure im making the right choice before i give them 450 bucks
quick run down on what i want done.
-ac stuff removed
-evap removed
-abs stuff removed
-traction controller removed
-cruise controll removed
-maf removed(gone 3 bar)
-repin vss for th400
-extend the harness wanna put pcm and fuse boxes in car
thanks
Old Jul 2, 2010 | 04:20 PM
foff667's Avatar
LS1TECH Sponsor
we use speartech for all of our bench harnesses & stuff and have heard nothing but good stuff regarding their engine harnesses, in fact we worked very closely with John over there on several things to make engine swaps simpler.
Old Jul 2, 2010 | 04:52 PM
velox65's Avatar
I tried to use em to build my swap harness for my ls conversion, I sent them several email's with no response, but i've heard they are good but no personal experience
Old Jul 2, 2010 | 09:56 PM
cutlass_455's Avatar
I used Speartech. John does great work there. Not much of a talker, probly cuz he pretty busy I think. I was pretty happy with my harness when I got it back and seen how simple how the hook up was going to be. The one thing I would suggest to specify if starting with a truck harness is make sure to specify you want DUAL fan control, not just single. I got a bit screwed on that one, I only have wires in my harness for control, but the ECM is good for the 2 fan/2 speed operation.
Speartech = good, just be make sure you think of EVERYTHING you want/need.
