Looking for a 100mm Maf table
Like the title says, I am looking for a few examples of a 102mm MAF calibration table. I'm not entirely convinced mine is quite right.
Stock bottom
TS 228R .590 114lsa cam
PRC 5.3L Stage 2.5 heads
Precision Racing 37lbs inj
Stock GM Head Gasket
PRC Dual valve springs
Stock rockers
Long tubes through cats
Fast 102 int and PTM 102 TB with TS 102 MAF
Stock bottom
Stock rockers
Code:
MAF Airflow vs. Output Frequency 3.85938 4.48438 5.25000 6.08594 6.93750 7.87500 8.92188 10.07031 11.70313 13.32813 14.95313 16.57813 18.20313 20.10156 22.25000 24.16406 26.38281 28.33594 30.59375 32.57031 34.53906 36.89063 39.28906 42.39844 46.14063 49.60156 53.21094 57.00000 61.00000 65.20313 69.67188 74.37500 79.33594 80.32031 80.40625 80.40625 81.96094 81.81250 83.35156 86.85156 93.37500 99.89844 106.42188 112.95313 119.46875 125.75781 132.28906 139.02344 145.99219 153.20313 160.65625 168.40625 176.45313 184.75000 193.34375 202.21875 211.39063 220.85156 230.52344 240.49219 250.75000 261.35156 272.31250 283.64844 295.39844 307.57813 320.23438 333.39844 347.11719 361.42188 376.36719 391.99219 408.34375 414.71875 414.71875 414.71875 414.71875 414.71875 414.71875 414.71875 414.71875 414.71875 414.71875 414.71875 414.71875
Here is mine.
Code:
4.32031 5.10156 6.35938 7.96094 9.60938 11.25781 12.62500 13.75000 15.62500 16.91406 18.72656 20.91406 22.96875 26.13281 29.21875 31.09375 33.73438 36.17969 38.49219 41.15625 44.10938 46.82813 50.03125 53.11719 56.78125 59.59375 62.09375 65.98438 71.23438 76.44531 78.15625 88.01563 94.48438 98.52344 103.01563 114.69531 117.55469 127.81250 131.33594 143.31250 149.54688 156.77344 165.46875 172.97656 181.59375 192.67188 202.69531 214.04688 221.87500 232.85938 239.85156 253.41406 268.19531 276.03906 284.16406 296.42188 308.11719 320.33594 334.21094 347.90625 368.51563 385.12500 401.18750 424.04688 448.88281 476.28125 505.60156 511.99219 511.99219 511.99219 511.99219 511.99219 511.99219 511.99219 511.99219 511.99219 511.99219 511.99219 511.99219 511.99219 511.99219 511.99219 511.99219 511.99219 511.99219
It's not ever going to be right if you are trying to copy a table. It will be right when you hook up the wideband and tune the MAF for your application (make your own curve).
They are sensitive... you can tune them and then rotate their housing and the MAF curve will change. You have to tune it for your own application.
