Wiring problems or maybe bad ECM ??
Old Jul 13, 2010 | 11:04 AM
70ls1chevelle's Avatar
Default Wiring problems or maybe bad ECM ??
I have a 70 Chevelle that i installed an LS1 in about 6 years ago and ran great then last year i swapped to a 402 LS engine,it sat for a long ttime in between.Now i cant read the ecm through the obd plug it says its not plugged in,i have tried 2 different 99 ecm's no change.And fuel pump wont cycle on through relay,turns over but wont fire ?Very possibly a wire not hooked up or grounded where it should be. Can anybody help i suck at wiring,anybody on here good with this king of stuff ?
Old Jul 13, 2010 | 08:58 PM
poconojoe's Avatar
Does the OBD2 connector have 12 volts on it?
Old Jul 13, 2010 | 09:53 PM
Yes 1 wire does i think orange wire
Old Jul 14, 2010 | 05:09 AM
poconojoe's Avatar
Then make sure the class 2 data buss wire has continuity from the connector to the PCM plug
Old Jul 16, 2010 | 11:39 AM
BUMP anymore input
