WIll anything read airbag codes?
Old Aug 1, 2010 | 12:23 PM
toplessHO's Avatar
Default WIll anything read airbag codes?
that is besides a tech2?
Im having an intermittent air bag light on my 02 Lade.
Old Aug 1, 2010 | 06:22 PM
Reaperchild's Avatar
Wink
i opened up the 4 bolts under the steering wheel & found a button with a broken bracket M6 & a hard lanch can break ur clutch switch dunno for A4 but i guess u should start random diagnosis =P
Old Aug 1, 2010 | 09:41 PM
toplessHO's Avatar
not one of my F bodys
Its my Escalade
will go off and on with hard acceleration or braking
Old Aug 2, 2010 | 03:32 PM
toplessHO's Avatar
Ne1?????
Old Aug 2, 2010 | 11:04 PM
flintwrench69's Avatar
Snap On Solus & red brick, Autoengineuity or an OTC Nemesis will read air bag codes. The Snap On red brick scanner can be had for fairly cheap on ebay. An OBD2 scanner like at auotzone will only read engine codes. Even if you could pull the codes you would need some good service info & the knowledge to find & fix the problem.
Old Aug 3, 2010 | 07:01 AM
toplessHO's Avatar
Ive got a "brick" but the cartridge only goes to 01 and this is an 02.
Maybe I can convince my buddy to let me use his black cartridge.
I have service info but would like to find out where problem is to start looking for a bad connection.I have AutoTap(wont do airbag or VATS) and a superchips Max microtuner
Old Aug 5, 2010 | 06:47 AM
toplessHO's Avatar
borrowed a brick with an updated black cartridge.
wiggled connector under driver seat...problem solved.
Guess I will look for a black cartridge for my MT2500
Anyone have one to sell? if so PM me
Old Aug 22, 2010 | 08:39 AM
toplessHO's Avatar
got a black cartridge for my brick...all set
Old Aug 22, 2010 | 09:34 AM
poconojoe's Avatar
EFI V2
I never tried using it for that, but the other day one of my co-workers had the SES light on his 2001 Chevy pick up and when I scanned it for codes with the V2, it also showed an SRS code being present
