IAT issues?!?
Stock, the IAT is a separate sensor that is located in the upper air box (the "lid"). The stock MAF sensor should have three wires running to it - if that has been changed to a later MAF (like an 85mm piece, or the new card types), those will have 5 wires running to them - the other two are for the IAT sensor since those bigger MAFs have an integrated IAT sensor. If you are running the stock 75mm MAF, the IAT sensor ain't in there.
The first thing I'd do is make sure the IAT sensor was indeed hooked up, and if so, make sure the wiring isn't reversed. On my car (when stock), the IAT sensor wires were in the same area as the IAC stepper motor, TPS sensor, and MAF.
I know this is a little redundant, but do you know what size grommet or anything to use (or is there a write up on this?). Just trying to save time.
