need advice for 402 drivability
Old Oct 3, 2010 | 07:52 PM
35th camaro's Avatar
if i would go with hpt would i be ok with standart or would i need pro, and does windband work on both?
Old Oct 3, 2010 | 09:26 PM
ctd's Avatar
ctd
Be a Pro!
You absolutely need a Wide Band, no option no choice.
Your making a big step here, don't cut corner's.
Old Oct 4, 2010 | 05:45 PM
does that mean that the wideband doesn't work with the std hp
Old Oct 4, 2010 | 06:38 PM
MUSTANGBRKR02's Avatar
Buy the pro version. You can run the wideband on a standard but then you have to mess with offset voltage etc etc..
Old Oct 4, 2010 | 06:44 PM
ctd's Avatar
ctd
NGK AFX Wide Band is a class favorite, accurate & reasonably priced.
Someone offers a deal when you purchase HPT & a WB together.
