LY6 No start no injector pulse
Old Aug 6, 2010 | 05:22 PM
twin74s's Avatar
Default LY6 No start no injector pulse
Heres the scoop. 07 LY6 E38 ecm. Have Crank, Cam signal. Has spark. No injector pulse. VATS is disabled and car will run if you spray brake clean in the intake. My Modis scanner shows that it has injectors pulse. HP tuners shows injector pulse but i never get a noid signal. All injectors have power during cranking and key on.
Things im not sure of. Accessory wakeup serial data wire?
What does this do and what should it be hooked too?
With a volt meter hooked to power and to the ground side of the injector wire it will show ground with key on. Normal? But the ground will not light a test light.
Any help would be greatly appreciated.
THanks David
Old Aug 8, 2010 | 06:58 AM
LS1MCSS's Avatar
Here is what I found on the accy serial data wire. Looks like it shouldn't have to be connected.
The accessory wake up line is an accessory fed power feed to the ECM and TCM (etc).
It is there in most cases to support "wake up" of low speed serial data when the key is on accessory, vs ignition on/engine running.
Old Aug 9, 2010 | 01:32 PM
wait4me's Avatar
did you do a full flash after you killed the VATS?
Old Aug 9, 2010 | 05:38 PM
twin74s's Avatar
I didnt do the tune myself. I had a local tuner do it. I will have to ask him.
Old Aug 10, 2010 | 09:01 PM
sho-me speed's Avatar
Closed ex-Sponsor Account
Asked this question on another forum and I was under the impression that he had it redone.
Old Aug 11, 2010 | 04:15 PM
twin74s's Avatar
It was a full flash. Im lost. Guess this thing is just destined to stay in the garage
Old Aug 17, 2010 | 08:52 AM
buddyholly's Avatar
Have you checked the fuel pressure at the rail? You are showing injector pulse while cranking? My LY6 cranked and ran from the first time I put power to it. I do not have the accessory wakeup wire connected.
I just cranked my L76 on my test stand over the weekend and it was pissy about cranking. It finally did, but it was difficult about it.
Do you know if you have your fuel pump set to "Fixed"? Seems like my LY6 was not and I had to change that setting.
Bounce some more ideas off me and I can check them against my LY6 setup.
Old Aug 17, 2010 | 11:15 PM
twin74s's Avatar
starter enable wire.... Needs to see a ground? Took it to a friends shop and he came up with that and now it starts and runs. Did you have to do this also?
Old Aug 17, 2010 | 11:18 PM
twin74s's Avatar
just read your truck swap and seen the starter check disable... Guessing that would make it so i dont have to ground that wire?
Old Aug 18, 2010 | 06:36 AM
buddyholly's Avatar
Yes, the starter check disabled kept me from having to run the ground wire...Great news, glad you got it running...
Old Nov 19, 2010 | 01:33 PM
v10rodder's Avatar
Don't know if you will be back online, but I just went through my LY6 startup today. Without your help it would have taken me days to wring it out. The grounding of the fuel pump relay and starter relay ECU pins were the last key issues.
Thanks much.
v10rodder
Old Jan 29, 2011 | 10:23 PM
dropedss86's Avatar
thank you We where racking our brains out with the same stuff ripped apart the whole harness and then I found this post.
Old Feb 1, 2011 | 10:10 PM
twin74s's Avatar
Glad to help, the info is here if you search for it
Old May 10, 2013 | 09:58 PM
bpmathy's Avatar
Smile you guy are the best
Found your thread, and it pointed me into the correct place after a week.ran the wire, no go, shot the Camshaft position no go, changed the disable engine crank, and off the beast went. cheers to all
71 GMC stepside LY6/6L90
