Spark Advance Dip to -10 degrees
The entire logfile can be viewed here
Thanks.
For kicks, enable TCS, log a file like you did earlier(try to get some tire spin) and see if it replicates the same info. Do you have a M6 or A4?
It's snowing here.. and gonna snow for a couple of more days.. I need to get another logfile.. I actually have about 3 other log files where I do not see this -10 degrees drop.. That's why this one interested me..
I'm not certain of what's going on, because I wasn't driving. But if it was my car it would seem the easiest test would be to 0 out upshift torque reduction.
It's very hard to catch the -10 drop during logging with a M6, but it does happen. I'll bet that's your culprit. On an A4 with a shift kit it will drop during a hard upshift and hold the -10 until you peddle it (I had this problem with my WS6).
Frame 181 looks the same, he's in a different gear and stabs the throttle to 100% where it goes to to retard limit of -10 backs off the throttle again to 60% until the tirespin stops and let's him go to 100% throttle again in frame 192.
My car is a 2002 WS6 M6. 4000 miles
Just a Lid....
Let me know what you think.. thanks.
Its been proven several times that people at the drag strip trip several knocks in a row, and spend the rest of the day with low timing UNTIL more fuel is added and the Bad Gas bit is mentioned in GM documents.
I've tested this on my '99 C5 and the function is there.
You mentioned you even tested this on your C5, please either show the hard facts or please explain how you proved it or disprove what is shown on the EFILive website.
I know you dislike cyberspace B.S, you often say so, so please lets sort this out once and for all.
2nd I gave my input as to seeing PCM into constant low octane table and by adding fuel PCM went back to hi octane, and lastly as I said YOU READ the GM documents as it states there is a bit flipped when PCM sees several constant knocks and common sense says they would use the low octane table for a bad grade of gas issues.
it would be stupid to think they have a low OCTANE timing table that would not protect the engine when there is a gas grade problem, esp for a $45,000 Corvette.
Again, not ALL models are equal and we all know Corvettes REQUIRE high octane where in other models it is suggested.
GM does not have content in their service manuals for nothing stating :
Add the specified amount of fuel. 19 liters (5 gallons)
Operate the vehicle within the conditions of the customers concern.
Does a driveability condition still exist?
Yes - Go to Step 6
No - Go to Step 29
Yes - Go to Step 6
No - Go to Step 29
What do you think is going to happen to 5 gallons of 91 Octane when you stick in 5 gallons of say 98 Octane?? Yeah, Knock will reduce, therefore the adaptive scaler will 'eventually' get back upto 100%.
It was proven on a Camaro that adding fuel does NOTHING to the adaptive octane scaler value, only driving the car with reduced knock activity will get it back upto 100%. But then, you refuse to look at that evidence.
Still waiting on the answer as to how GM can run twin maps in cars that do not have a Fuel Level Sensor into the PCM?. That's gotta be somewhere in your Technical Manual
Imagine a used car dealer telling you that they know how to put gas in ALL the different brands of cars they have on the lot, because they know how to read the manuals.
MRK
PS: Now I see why those EFILive people have to work so hard to just tell the verifiable truth. It's the "Red Convertible Syndrome" again... No matter how authentic and correct your car is at an antique car show, the red convert always wins...
The only saving grace is that you, and those that really know the truth, genuinely appreciate it, and we know that pop culture is just some idiot's impression of the facts. It is the same in the business environment.
