Here we go, P0418 code.
1. Circuit relay defective or fuse open.
2. check connector and wiring
3. Air Pump defective or hoses blocked
So basically what is my course of action? Replace the relay? Then work my way up? And since I've never really worked on the AIR pump system where is it located and what does it look like, aside from replacing the relay (which I can figure out) how do I perform the last 2 actions.
Also I planned on driving my car up to Cleveland this weekend (I live in Dayton) to have my rear end worked on, will this cause a problem with the trip? Will it force my car into a limp home mode? Or will I be ok? Any information or input will be helpful.
Thanks
Did you check for voltage to the relay?
Did you check the grounds?
Did you look for damaged or corroded pins in the terminals?
Did you check power to the air pump with the relay grounded?
There is a lot to diagnosing electrical problems and DTC's, that's why technicians make big money if they are good.
Thanks for your help.
