Need help with testing MAP Sensor
Old Sep 16, 2010 | 12:02 PM
rockoosi1's Avatar
Default Need help with testing MAP Sensor
I just finished installing a LQ4 into my 89 Camaro. This car has a turbo and I'm about to start trying to tune the thing. I started of by clearing all of my DTCs as well as playing around with my PE tables.
While logging last night I noticed that I'm not getting any reading for my MAP sensor. I checked my wires to make sure it was plugged in and it was. Can somebody tell me how to test my MAP because I know PE needs a working MAP correct? Thanks!
Old Sep 16, 2010 | 03:01 PM
BLK02WS6's Avatar
Are you sure you have the right PID selected?
Old Sep 16, 2010 | 03:20 PM
rockoosi1's Avatar
At the risk of sounding even more like a rookie I'm not sure what you mean. I noticed that the MAP wasn't registering anything while using the HPT scanner. It just sat at 10 kpa.
Old Sep 16, 2010 | 03:51 PM
rockoosi1's Avatar
After reading your question again and doing a little more research, Yes I have the correct PID selected. Any idea how to check the sensor?
Old Sep 16, 2010 | 08:48 PM
rockoosi1's Avatar
Problem solved. It turned out to be the signal wire wasn't making contact with sensor.
