stock tachometer not working
Old Sep 27, 2010 | 06:13 PM
djfury05's Avatar
Here is the bundle of wires. There are 12 Total on this bundle of wires. Colors are as follows:
(2) Solid Gray
(2) Solid Black
(2) Solid Red
(1) Solid Green
(1) Solid Brown
(2) Pink w/ Black Stripe
(2) Brown w/ White Stripe
There is another single Solid Red wire on another bundle of wires right behind it. It is sticking up and has electrical tape covering the end.
I know that the (1) Solid Green wire and (1) Solid Black wire go to the A/C connector. That eliminates (2) wires.
Here's the question now. After we determine which wires need to be connected, can I just strip them and solder them together, or will I need the connector pieces?
Old Sep 27, 2010 | 06:30 PM
djfury05's Avatar
BLUE PCM CONNECTOR
41
BLACK
EGR Pintle Position. Sensor Ground.
47
GRAY
EGR Pintle Position. Sensor 5V REF
55
BROWN
EGR Pintle Position. Sensor Signal
61
PNK/BLK
Camshaft Position. Sensor Ref. Low
73
BRN/WHT
Camshaft Position. Sensor Signal
RED PCM CONNECTOR
7
RED
EGR Control
39
RED
Camshaft Position. Sensor B+ Supply
41
GRAY
EGR Position Sensor Ground
This info taken from: http://www.ls2.com/boggs/torques/99pinpcm.htm
These (8) wires listed take care of (10) wires with the (2) A/C wires included of the (12) wires. I am still missing the purpose of (1) PINK/BLACK wire and (1) BROWN/WHITE
Old Sep 27, 2010 | 08:34 PM
djfury05's Avatar
*UPDATE* I have taken apart the wiring harness and traced each wire listed above ^^ back to the PCM. There are 4 wires that do not lead to either the blue or red connector on the PCM, rather behind the intake in another wire loom that I haven't traced.
These are the 4 wires leading back behind the intake. (1) each: Solid Black, Pink/Black, Solid Red, and Brown/White.
These are the other wires I have already traced.
Old Sep 27, 2010 | 09:32 PM
Slowhawk's Avatar
LS1Tech Sponsor
Shoot me a call at my shop tomorrow.I'm pretty sure a customer is dropping off a 00 Z around 10am. On the phone I can atleast tell you the colors.The other side would be the 3-4 wires that don't go back to the pcm. Should be easy enough to figure out.
Old Sep 28, 2010 | 09:04 AM
djfury05's Avatar
I believe I've got it figured out.. the 4 wires in back need to be connected to RED 41, 61, 73, and BLUE 39. All the colors correspond and if on original wiring, there were 2 connectors, male/female, this is why there would be extra wires that I can't find where they are going. I am going to splice and try it after I give Slowhawk a call
Old Sep 28, 2010 | 09:40 AM
djfury05's Avatar
yep... I fixed it =).. back to the tuner the car goes to get idle fixed now.
Old Sep 28, 2010 | 05:05 PM
Slowhawk's Avatar
LS1Tech Sponsor
Did I win anything? LOL
Old Sep 28, 2010 | 05:21 PM
MUSTANGBRKR02's Avatar
Good one
Old Sep 28, 2010 | 06:58 PM
djfury05's Avatar
Originally Posted by MUSTANGBRKR02
Good one
lol ya.. it's running better now..
and thanks SlowHawk for the idea! =)
Old Sep 29, 2010 | 04:19 PM
0331gunner's Avatar
djfury05 you saved my life. Big help. He did all the work and got it fixed :-D You are the man!!!!
Old Oct 4, 2010 | 11:43 AM
ls1racer1999's Avatar
hey guys may i ask what wires you ended up putting together i have same problem i had cut those wires off also and i noticed the same problem i have a 99 trans am so i have a strong feeling what djfury05 said is the cause of it .
Old May 17, 2023 | 08:26 AM
  #32
Patrick Wade Shelton's Avatar
What was the problem
Old May 17, 2023 | 08:48 AM
  #33
He's still around. You might get a reply....
