Bad start up, idle, and no LTFT
Old Sep 26, 2010 | 11:20 AM
Fondle's Avatar
Default Bad start up, idle, and no LTFT
So i have been tuning the car i bought about 2 months ago, and i have got the WOT and cruising nailed down
but for some reason i cant get the idle right.. well my wideband makes me worry. the car will start up and run 13.5ish when cold and when it gets to around 100 it will stay around 14.7.. but once it gets closer to 171 which is my operating temp the wideband goes ---, i have tried adding fuel and i cannot get it to read anything, where should i be adding fuel? in the idle airflow, or the MAF calibration?
Also, on a cold start when i start the car up its SUPER choppy, for the first 10-15 seconds the idle bounces from 1000 to 400 and almost dies, and sometimes it actually does die and i have to re start the car, and if the car dies, the car will not start back immediately, i have to wait 15 seconds or so or the car will not turn over
and last, when ever i scan my car it never reads LTFT, why is this? is it bad?
Old Sep 29, 2010 | 06:27 PM
Fondle's Avatar
no help?
Old Sep 29, 2010 | 07:05 PM
69LT1Bird's Avatar
A log file and the tune file might get you some help.
Old Sep 29, 2010 | 08:57 PM
cyclerage's Avatar
log your front O2s on your cold start, youll probably find that you running lean (.01 to .4). Ifso you can either add fuel to your open loop comanced fuel or lower your desired idle air by temp.
Old Sep 30, 2010 | 07:27 AM
Old Geezer's Avatar
And which car are you referring to??
Old Oct 3, 2010 | 04:18 PM
Fondle's Avatar
the h/c/fast 92 SS, not the v6, i can post a log file later, ill try adding some more fuel
