Po442
Old Sep 30, 2010 | 10:47 PM
Midnight00SS's Avatar
Arrow Po442
Evaporative Emisson Control System Leak Detected, had this before and and after my tune???
Old Sep 30, 2010 | 11:16 PM
wut does this mean ?
Old Sep 30, 2010 | 11:43 PM
RsSean's Avatar
means you have a leak some where, could be your gas cap being loose, your evap vent solinoid be F'd up, a crack in one of the plastic hoses. Smoke testing the evap system is one of teh ways to find your leak, but you need a Tech 2 to seal the and purge the evap system.
Old Sep 30, 2010 | 11:58 PM
ok where is the evap vent solinoid located?
Old Oct 1, 2010 | 11:16 AM
badcoup's Avatar
vent solenoid is back by the tank, has a 2 wire connector you can close off the solenoid with any good scan tool that has bidirectional controls. You will need a smoke tester though. Your tuner could kill the light for that code if you want.
Old Oct 1, 2010 | 11:26 AM
someone told me about a solenoid by the intake?
Old Oct 1, 2010 | 01:01 PM
RsSean's Avatar
The vent is back by the tank should have a two wire connector on in.
The evap purge is on the intake drive side.
Old Oct 1, 2010 | 04:15 PM
badcoup's Avatar
the purge solenoid on the intake wont set a leak code.
Old Oct 2, 2010 | 12:00 AM
so how do i check this vent by the tank? wut do i look for?
Old Oct 2, 2010 | 05:06 AM
DynoDR's Avatar
A purge solenoid problem can set a leak code also.
Old Oct 2, 2010 | 04:59 PM
wut exactly is that?
Old Oct 3, 2010 | 01:16 AM
Light came on again
Old Oct 3, 2010 | 05:35 PM
THErobertH's Avatar
you should have a test port with a green cap on it specifically for testing the EVAP system. Introduce smoke into the system, wait a minute or so and look for leak with a flashlight in engine bay and under car. You should also hook it up at the filler, there are adapters that allow you to smoke the gas cap and tank, pump seals etc.
Old Oct 3, 2010 | 08:16 PM
ok cool will do, could this hurt performance at all?
Old Oct 3, 2010 | 11:55 PM
THErobertH's Avatar
well you do it with the car off. As far as i know smoke machines generally pump the smoke in at 1 PSI or less, as soon as the car starts the smoke is pretty much gone, it doesn't mix with the gas or anything like that. Can't really think of any ways it could hurt performance. I guess you could say its like mixing food dye into water, changes the way it looks but nothin else.
Old Oct 4, 2010 | 12:11 PM
ok i see, yea im gonna take it into the shop soon to get it checked
