Ltb2 +25
Old Oct 11, 2010 | 11:03 AM
BlackSS2001's Avatar
Question Ltb2 +25
Ok here's what happened. I went to the lake for the weekend a while back. Car drove fine there. I parked it at the house and had my lake fun. When it was time to head home I jumped in the car and headed back home. I notices a violent vibration from 1500-2500 rpm range. (Idles fine, vibration goes away after 2500, but the car runs like a pig now) I get home plug in HP tuners and saw that my LTB2 was in red and sittign at +25. O2s are staying at the same number area not bouncing around like I'm use to seeing. I took the O2s and switched them side to side, nothing changed so I took all of the B1 and B2 injectors and swaped sides (and put all new O-rings on). Nothing changed. I have checked for intake leaks and exhaust leaks and there is none. I put new plugs and wires in. Plugs showed the signs of running lean but also looked to have extra fuel on them.. I checked all the valve springs and rockers and there fine.
I'm not sure where to go from here.
Specs on car. MS4 cam, no cats, deleted rear O2's, kooks headers & Ypipe,
Old Oct 11, 2010 | 06:42 PM
sreve's Avatar
Quote ; deleted front O2's
I'm sure you meant the rears?
At +25 trims its gonna spit some codes P0171 & 174 and what else?
Whats the fuel pressure?
Old Oct 12, 2010 | 08:58 AM
haha yeah my bad I'll fix that. My brain is becoming mush from thinking aout this so much!
I have no codes at all. Nothing... I want to say fuel pressure was between 58-60psi..
Old Oct 14, 2010 | 08:35 AM
Bump for some help!
Old Oct 15, 2010 | 03:49 PM
anyone?!? I'm not sure where to go with this now...
