Ford 39lb Injector questions?
Old Oct 12, 2010 | 12:47 PM
Quick99TransAm's Avatar
Default Ford 39lb Injector questions?
I am maxing out my stock 28 lbs the are at a 105% duty cycle.So i bought some 39lb ford injectors and i ordered the ev6 connectors not the adapters my question is whats the best way to change the connectors out.Can i just remove the pins from old connector with the wires still attached and put into new connector or do i have to cut wire and use new pins.which the connectors come with new pins.
Old Oct 12, 2010 | 01:18 PM
Lambert695's Avatar
you might be able to just throw the pins on there.. but I would do it the right way. This way all the connectors are insulated from any dirt or water and such. Should have got the connectors.. or bout the Ev1 series and just thrown them in.
Old Oct 12, 2010 | 01:48 PM
2xLS1's Avatar
https://ls1tech.com/forums/fueling-i...injectors.html
