OL TO CL Question
Idle1 tr30 is olsd run and the tets is after I enabled all of the CL parameters and delete the .doc.doc file extension on the cfg file, I couldnt get it to load a .cfg to load it on here
Tune the MAF by itself now... Once its good plug back in and the car should be awesome if your VE is where you want it. Even though MAF controls WOT and RPMS over 4000, it does reference it down low. When you log the MAF, take notice to the grams/cylinder @ idle... you can use that number to fine tune your idle at the end. Gonna assume that your calculated air flow and MAF are in disagrement causing your issues?
Still learning, just giving my .02, if I am wrong anywhere, please correct me.
