Need Help with Surging Idle
A few of your problems may be related to the fueling you have. When it is in open loop at the beginning if your key cycle, it dumps more fuel in, leaving a cushion for it to run on. Then closed loop comes in and ruins the party. You will need to adjust your closed loop fueling now at idle. When you were SD/VE tuning....did not you do idle first? Alot of books/write ups assume either your idle is fine, or that you have already addressed it.
you were probably told to take care of fueling first, then idle...which means take care of VE first and then the Idle spark and airflow tables after that.
honestly its an all in one kind of thing...
you cant just focus on one part at first.. you have to do all 3 at once to get the car stable enough to actually tune on it.. after its stable you can break it down to the individual parts.
the MAF isnt always the best answer...but it definitely acts like a sponge and soaks up a lot of the errors involved in tuning.
its certainly easier to tune a car that is 100% MAF vs ones like our Fbody's that use a blend of VE and MAF normally.
being in SD its definitely easier than trying to get both VE and MAF to jive together correctly.
if the car starts up fine, then you really dont need to mess with frictional or startup airflow tables...and I'm not talking about idle swings 10 seconds after startup... I'm talking about the initial turn of the key to get the engine to fire up.
Use the same histogram that you used for the VE tuning, just let it idle and see what the cells show. Do not let it idle too much though without driving it some in between to let the O2s breathe some fresh air. Then go back at it.
To be honest, I would not have stepped away from the MAF.
Throttle Cracker is for airflow when the car is in "coast" mode... cruising down the road.. let of the gas.. clutch still engaged...
typically it decays to 0 when you push in the clutch.. in an automatic its usually responsible for any surging and bucking you get while coasting.. too much and it bucks..not enough and it dies...
but it can be spark, it can be fuel , and it can be IAC table...
you cant just blindly move over the IAC... your desired airflow and dynamic airflow should closely match during deceleration of rpm's... its not an eassy tassk to get them to line up...
if you had a stock throttle body, you wouldnt have to mess with that table much.. its pretty close... but with your 80mm BBK its gonna need some adjustment. I couldnt tell you how much...
