Iac
Old Oct 29, 2010 | 09:45 AM
guffey24's Avatar
Originally Posted by Frost
the 896 and 411 PCMs have the driver, are fairly common, and will run that engine well also..
I have a 6.0, computer and wiring harness in my buggy from a 2001
I am sending Jim all three computers and he is going to use a different program for the tune
If CalEditor is right, the test computer has no IAC drivers, my original does, and the 2001 computer has to have them
Old Oct 29, 2010 | 09:48 AM
CalEditor's Avatar
Originally Posted by guffey24
well this makes some since
my computer numbers
serv. No. 12586242
hwd. no. 12583660
Test computer I got yesterday
serv. no. 12589463
hdw. no. 12589162
The idle just slowly get higher and higher until it max's out.
I use a 12586242 as a test PCM. I installed it in a 2004 C1500 4.3L. The truck started. That was the issue, but the Idle slowly went up.
I personly like the 1mb PCM's, but most of the info I have is on them.
Old Oct 29, 2010 | 10:17 AM
guffey24's Avatar
well neither computer will change the IAC position, both have the same tune exactly. He thinks something is wrong with the tune, so he is going to put a different tune in my original computer
serv no 12586242
hwd no 12583660
Old Oct 29, 2010 | 10:34 AM
CalEditor's Avatar
Look at the pictures in this post
http://www.monodax.com/forums/14404-post1.html
Old Oct 29, 2010 | 11:30 AM
guffey24's Avatar
I cant see the pictures, not a member
Old Oct 29, 2010 | 12:07 PM
CalEditor's Avatar
GTO PCM with IAC driver
PCM without IAC driver
Old Oct 29, 2010 | 01:02 PM
edcmat-l1's Avatar
Can the idle be forced up or down using the scanner bi-di controls?
Any chance youse guys have a hand held IAC tester? Nifty little tool.
What does the scanner say? Is it trying to force the IAC one way or the other? Or is it sitting still?
Old Oct 29, 2010 | 01:07 PM
CalEditor's Avatar
serv no 12586242
hwd no 12583660
His PCM doesn't have the hardware to drive the IAC, so it doesn't mater and it works in the other truck.
Old Oct 29, 2010 | 02:16 PM
Mike454SS's Avatar
Originally Posted by jimmyblue
Are you the PCM is right for the job? Some PCMs have
the IAC driver circuitry missing.
Measure each IAC phase to GND with a DMM with the
engine running, poke through the insulation with a
needle & clip-lead. If you see less than 100mV on all
of them, the PCM isn't trying.
Ran into this on an '04 Silverado AWD doing a big cable
TB swap, had to go to an '03 Savana PCM.
I don't think you should ever pierce the insulation of any wire for any testing at all...especially wiring in an engine bay...thats just bad plain advice. There is ALWAYS a way to test it without putting a hole (even just a pin ***** is still a hole) that compromises the insulation of the wire.
Old Oct 29, 2010 | 02:33 PM
guffey24's Avatar
I can move the IAC plunger in and out by hand, and it idles up or down, but the PCM will not move it, the IAC is working properly
The scanner I have doesnt read IAC counts
it is sitting still, where I move it by hand is where it stays
Old Oct 29, 2010 | 02:35 PM
guffey24's Avatar
wait a minute, your first post said my orginal computer does have IAC drivers
I have an 8 in the hwd no. instead of a 9
Old Oct 29, 2010 | 02:42 PM
  #32
CalEditor's Avatar
PCM's with IAC drivers
SERV. NO.- HWD NO. -
12576106 - 12570558 - 2003 G-VAN, LM7, IAC DRIVERS INSTALLED. ALSO C-TRUCK LM7
12582605 - 12580786 - 2003 C-MPV, L59
12586242 - 12583660 - 2004 C/K-TRUCK, LM7
12586243 - 12583659 - 2004 GTO LS1, IAC DRIVERS INSTALLED
12589462 - 12589161 - 2005 G-VAN, LQ4, IAC DRIVERS INSTALLED
12589463 - 12589162 - 2005 C/K-TRUCK/MPV, LM7, LQ4
12589463 - 12589162 - 2006 C-PICKUP, LM7
12602802 - 12589162 - 2006 C-PICKUP, L59
12602801 - 12589161 - 2006 - 2007 Express, Drive by Wire, (has IAC drivers)
Green is good Red is not
I should have made that more clear like this. Sorry about that
Old Oct 29, 2010 | 03:00 PM
  #33
guffey24's Avatar
well there ya go, no IAC drivers installed equals no idle
Old Oct 29, 2010 | 03:03 PM
  #34
CalEditor's Avatar
Sorry about that and I just read the first line of that. "PCM's with IAC drivers
Old Oct 29, 2010 | 07:50 PM
  #35
guffey24's Avatar
thanks for all the help, I am sending out my 2001 6.0 ECM for a tune on monday
