anybody got a engine harness diagram?
The connectors you're interested in are C100, C101, C105 (located on the pass side fender) and C220, C230 located passenger side footwell under the dash. There's one more connector near C100, single-pin purple wire that is the starter solenoid trigger. That's pretty much it.
C100-105 are power feeds (PCM, injectors/coils, sensors) tach output, fan and fuel pump relay controls, etc.
C220-230 are oil pressure gauge, brake/clutch pedal switches, serial data to the OBD-2 connector, etc.
