Ignition switch wiring
Old Nov 7, 2010 | 08:10 PM
SSilver's Avatar
Default Ignition switch wiring
I have a generic ignition switch from Kragen that has 4 posts that read
BATT
IGN
ACC
START
my other wiring is done just like this (thanks Pocket)
I'm assuming...
-I need a 12 AWG wire from my battery to the BATT on the ignition switch
- 12 AWG (?) wire from the Starter to the START on the ignition switch
- 18 AWG wire from IGN to the Key 12v+
not sure what happens with the ACC or would that also go to the Key 12v+ on the relay to power up the relay in the ACC position as well?
thanks guys
Also does the ignition switch get grounded?
Old Dec 7, 2010 | 08:42 AM
leon phelps's Avatar
did you ever get an answer for this?
exactly at the same place.
