ls1 PCM on lq9?
Old Nov 18, 2010 | 08:49 PM
My2000Z28's Avatar
Default ls1 PCM on lq9?
can i use my 00 ls1 computer on an lq9? if so, what if anything needs to be altered?
Old Nov 18, 2010 | 10:02 PM
CamaroSS22's Avatar
You need to change the fuel injector tables, cylinder volume, volumetric efficiency, and base running airflow numbers. There may be a few other small ones, but these are the cruicial ones to make the engine run correctly, especially the injector and and cylinder volumes.
Old Nov 19, 2010 | 07:20 AM
moehorsepower's Avatar
I have tuned an LS7 with a LS1 PCM so yes it can be done...
Old Nov 19, 2010 | 11:09 AM
My2000Z28's Avatar
makes sense. i have access to hp tuners. is something i can figure out or be walked through on my own? at least to get it drivable to a tuner? or should i just have it towed and let the have it
Old Nov 22, 2010 | 06:20 AM
When it comes to that stuff, I have no clue how its done or if there is a whole lot of splicing or what, sorry...If I remembered which customer it was i could ask him..
Old Nov 27, 2010 | 06:50 AM
GA95DCMSS's Avatar
Are you using the blue/green connector harness from the LQ9, or a red/blue harness?
Old Nov 29, 2010 | 09:55 AM
My2000Z28's Avatar
being debated right now, the harness off the lq9 is in great condition, where as my ls1 harness looks aged, and i had to repair some broken wires on it so its not perfect, though i'm not sure if its just plug n play...
