P0122 code help!
Old Feb 3, 2004 | 10:17 PM
lucky_topher's Avatar
Default P0122 code help!
I'm throwin P0122 code.. Throttle Position Sensor circuit low voltage... autotap won't let me clear the codes
how bad is it to drive like this? what all could it be?
first my ASR turned itself off and wouldn't let me turn it back on... then the SES light came on...
anyone?!
Old Feb 6, 2004 | 04:38 PM
NoGo's Avatar
It isn't an awful code. It isn't going to hurt the car. I don't know if it will affect some of the performance features of the car though (acclelerator pump etc...)
Most peope get it when doing a home job on the throttle body (grinding stops etc...). It can also be thrown by a bad connection.
Check you connections to your throttle body. Make sure that there is no water, dirt or anything in the wheather plugs. A bad TPS sensor can also throw the code.
Try swapping throttle bodies with a buddy and clearing the code to see if it is the TPS sensor.
Good Luck
Old Feb 6, 2004 | 04:50 PM
thanks i braved my way to autozone, got a new TPS for $27.99 w/ a 3 month warranty (boy they sure don't trust these huh)... and now i'm good as new!
