Teach me how to change front 02 sensors.
Old Feb 3, 2004 | 11:20 PM
LS1FIRE's Avatar
Default Teach me how to change front 02 sensors.
HOWDY Can somone give me step by step instructions on how to change the front 02 sensors.Also Were can i get a good deal on o2 sensors?What kinda of performance decrease can i see from having bad 02 senosors?
THANKS EVERYBODY
Old Feb 4, 2004 | 11:09 AM
you2slo's Avatar
To remove the O2 sensors: Jack car up. Get under car. Unplug bad O2 sensor. Unbolt bad O2 sensor. Bolt in new sensor. Plug in new sensor. Lower car.
It's that easy.
Old Feb 4, 2004 | 11:16 AM
minivette's Avatar
Don't touch the tip of the sensor with your bare hand tho...
Old Feb 4, 2004 | 01:46 PM
LS1FIRE's Avatar
Do i have to reset the ECM after?Is it alright if i use A different brand 02 sensor?
Thank yall
Old Feb 8, 2004 | 11:41 AM
Steve01SS's Avatar
You may want to reset the PCM to clear any stored codes, but it's not a must. It couldn't hurt. Also you can use a different brand sensor as long as it's the correct application.
