best PCM to use?
Old Nov 22, 2010 | 08:30 AM
95wannabe's Avatar
Default best PCM to use?
I know there's a sticky or thread somewhere with recommendations on which PCM to use for swaps. I've searched for a while and can't find it. Thought I had it bookmarked but don't.
Can anyone point me in the right direction?
Thanks
Old Nov 22, 2010 | 02:15 PM
Kevin01Z28's Avatar
Would help if you mentioned some details about the swap
Old Nov 23, 2010 | 04:45 AM
95wannabe's Avatar
Mine is LS3 top end (no TB yet) on LQ4 short, 4L60E, using 2000 LS1 fbody harness in a '95 body...
but the thread I was looking for wasn't swap specific. It had more general info on using the different PCM's available...pros/cons of each, what they came out of, which ones could use diff OS, had more tables to modify, more common, etc...
Old Nov 23, 2010 | 05:56 AM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
Originally Posted by 95wannabe
Mine is LS3 top end on LQ4 short, 4L60E, using 2000 LS1 fbody harness in a '95 body...
Unless someone jumps in and says I'm wrong, avoid the 98 PCM if you have a 99-02 harness.
Old Nov 23, 2010 | 03:31 PM
Kevin01Z28's Avatar
Do you have a DBW throttle body?
Old Nov 23, 2010 | 09:24 PM
95wannabe's Avatar
just the stock one from the LQ4. I'm not sure what size that is.
Old Nov 23, 2010 | 09:41 PM
Kevin01Z28's Avatar
I noticed in your original post you had an LS3 topend so i figured you may have an electric TB, no cable.
