v6 to ls1 swap in camaro
Old Nov 27, 2010 | 10:08 PM
jcob's Avatar
Default v6 to ls1 swap in camaro
wondering what i need to do with the pcm, i have a ls1 pcm and wiring harness, also have the factory 02 v6 pcm. which pcm would you recommend using? am i going to run into any communication problems? i'm new to this part. i know i'll have to have it tuned, but where is somewhere i can send the pcm and have a basic tune put on it to make sure i have everything working on the car before i take it to get it tuned at the dyno? i am located outside jackson ms. i can possibly get everything out of the ls1 car if needed, it is wrecked.
also the car is going to have a built 700r4 3800 converter. engine has .030 milled heads, with a little port work and a comp cam 54-459-11 stock ls1 intake and lt headers
Last edited by jcob; Nov 27, 2010 at 10:23 PM. Reason: added info about engine and trans
Old Nov 27, 2010 | 11:28 PM
Kevin01Z28's Avatar
The ls1 pcm. Plenty of mail order tuners if you need something to get you going. Are you ditching the 60e and going with a 700 or what?
Old Nov 28, 2010 | 12:26 AM
jcob's Avatar
actually the owner of the z28 has the 60e in another car already.
will i need to use the vin off the z28? i think its a 99
