O2 harness adapter
Old Dec 3, 2010 | 01:41 PM
voda1's Avatar
Default O2 harness adapter
I would like to use the the rear O2 sensors to replace the slow switching front ones. The problem is that fronts have flat 4 pin connector where as the rears are square 4 pin. Any one know of a adapter?
Old Dec 7, 2010 | 04:44 AM
LS1MCSS's Avatar
You could put the square plug on your harness, but I don't recall seeing and adapter for that.
Old Mar 7, 2011 | 11:18 AM
voda1's Avatar
The problem is the terminals are spade type in the flat connector for the front and female square in the rear O2 sensor.
