When you program using Edit, does it reset the PCM trouble codes?
Old Feb 8, 2004 | 11:09 PM
CAT3's Avatar
Restricted User
Default When you program using Edit, does it reset the PCM trouble codes?
Curious if it clears out the trouble codes or not. I know with Predator it did. Thanks,
Charlie.
Old Feb 8, 2004 | 11:10 PM
parish8's Avatar
single digit dreamer
yes along with the fuel trim tables and probably anything else that is stored in there
Old Feb 8, 2004 | 11:11 PM
parish8's Avatar
oh crap, i just hit 3000posts. i have a problem, i need help!
Old Feb 8, 2004 | 11:16 PM
CAT3's Avatar
Restricted User
thanks
Old Feb 9, 2004 | 09:55 AM
Bink's Avatar
Naw, you're just the helpful type...
joel
Old Feb 9, 2004 | 01:24 PM
TimZ28's Avatar
That is not true on the 98s. On the 99+ the trims will be reset. On the 98s the trims will still be there as well as the Adaptive Octane percentage. I use EFILive to clear the LTrims.
Tim
