Wideband placement
Old Jan 12, 2011 | 10:40 AM
BTLD_LS1's Avatar
Default Wideband placement
Hey guys,
I currently have my wideband installed in place of my driver side narrow band and just picked up a bung so Im looking to see where I should install it. I'm running Pacesetter long tubes and a catless x-pipe, for best results, should I be installing it at the crossover? or is there a preference in side or location?
THX
Old Jan 12, 2011 | 11:01 AM
Sweet_SS's Avatar
I would say about 6-8 inches from the head(s). You don't want it to close...for heat or to far that that it cools too much. I usually install mine 6 inches from my hotside (turbo).
Old Jan 13, 2011 | 02:05 PM
Red99TA's Avatar
How would you install it 6-8" from the head if you're running LT's unless you put it on one of the primaries? I've always heard about 12-18" from the collectors so the gases have a little room to mix before hitting the sensor. I would think the stock narrowband location would be fine.
Old Jan 13, 2011 | 02:12 PM
Greekey's Avatar
My wideband is placed approx. 4 inches from my 02 sensors after the collectors.
Old Jan 13, 2011 | 02:20 PM
BTLD_LS1's Avatar
thanks for the replies guys, i ended up installing it on the driver side about 6" into the xpipe
