check engine light on codes are...need help figuring out why
Old Feb 2, 2011 | 04:27 AM
2000ls1tranz's Avatar
Default check engine light on codes are...need help figuring out why
i have 2 codes on after my car was tuned 1 code is for maf sensor the other for map....guy says he turn maf sensor off cuz im running SD tune but why am i still throwing a code for it...also whats up with the map code???...also my air bag light is on for what reason idk but it never goes off
Old Feb 2, 2011 | 10:41 AM
Pulse_GTO's Avatar
What are the numbers? Like a P0103 and a P0106? Is the check engine light on, or are the codes just showing up on a scanner?
Old Feb 2, 2011 | 12:09 PM
the check engine light is on..... an i went to auto zone an scan it.. forgot the code codes numbers but it was a code for maf an map i have tried to clear them they just keep coming back..
Old Feb 2, 2011 | 12:36 PM
ZL1Killa's Avatar
Well, if you went SD, and the MAF light is still on, he forgot the MIL light status to be disabled.
You will always show a "code" in the computer for the MAF, now whether or not the SES light is on for that specific one....
your other code.. is the MAP reconnected? Did the tuner accidentally turn off the MAP?
Old Feb 2, 2011 | 01:04 PM
Frost's Avatar
0106 is MAP/performance. It needs attention if the cam has been swapped because the car will idle in a different MAP range.
Old Feb 2, 2011 | 01:06 PM
Frost's Avatar
The number is what is is important, not the text description some guy at autozone gives you
Old Feb 4, 2011 | 01:15 AM
oic..well when the car comes back out i will scan an write codes down an let u know..... is there a way i can put my tune on here an maybe u give me ur opinion of what u think bout it an stuff????
