Keep or ditch front O2's for Open Loop tune
I plan on a Speed Density OL tune which uses predetermined values in the bin files. Is there any other need for them or can I just delete them off the harness?
Is there a way to run a 0-5 volt (from wideband) to the ecm and have it work in closed loop fueling?
Im planning on using a single wideband and ditching the stock o2's, unless there is a dying need to ever keep them around.
Thanks
I would question why you would want to run open loop anyways. What's the setup? Race car only? Crazy cam? I've run plenty of radical setups in closed loop.
